Latest, Mac. -
Accessing the dashboard API. -
Making a fetch request from express app -
What happened?
I am receiving a 401 unauthorized response. -
I created a service account token that never expires, and i expected to receive access. -
grafanaRouter.get(‘/tags’, async (req, res) => {
console.log(‘Inside grafanaRouter’);
try {
const response = await fetch(‘http://grafana.staged-by-discourse.com/?orgId=1/dashboards/tags’, {
method: ‘GET’,
headers: {
‘Accept’: ‘application/json’,
‘Content-Type’: ‘application/json’,
‘Authorization’: ‘Bearer sa-front-dc4671a0-1827-4758-8f86-317b5d8ca6ae’,
if (response.ok) {
const data = await response.json();
res.json(data);
} else {
console.error('Failed to fetch tags:', response.status, response.statusText);
res.sendStatus(500);
} catch (error) {
console.error(‘Error:’, error);
The response I receive is, Failed to fetch tags: 401 Unauthorized. -
I followed the the API Dashboard docs
