Hello. I am using Grafana Enterprise Open v10.4.2 with MySQL data connector. I have defined multiple template variables which get used in the following time series visualization:
select
	date,
  sum($category)
FROM
    grover.accountInfo
INNER JOIN
    accountData ON accountInfo.switch_key = accountData.switch_key
WHERE
   $__timeFilter(date) AND
   config_count > 0 AND
   account_name IN ($account) AND
   geography IN ($geo) AND
   region IN ($region) AND
   sub_vertical IN ($vertical) AND
   sector IN ($sector) AND
   accountData.switch_key IN ($switch)
GROUP BY
	date
ORDER BY
	date ASC
The results are nice - everything works. The template variable called $category is defined not using Multi-value and All. However, I now want to enable Multi-value, which causes a problem. The
sum($category)
without multi-select works fine because it gets translated as
sum(field)
But when Multi-value gets enabled the statement is now:
sum('field1','field2','field3')
which fails because it is not a correct SQL statement. The correct SQL syntax is:
sum(field1+field2+field3)
Can anyone suggest how I could correctly aggregate a multi-select template variable?
