Hello!
TL;DR = when using the data source proxy, data doesn’t seem to be processed for {{ .SecureJsonData.someSecret }} style parameters. Is this intentional or a bug? Please read on…
I needed to implement my own token auth, since the tokenAuth feature of the data source proxy isn’t an exact fit for my needs for 2 reasons:
My token auth service requires data be posted as
application/json– but it appears Grafana only provides support forapplication/x-www-form-urlencoded. Is there a way to force it to post JSON instead? -
My token auth service requires an
audienceattribute instead ofresource. In other words, I need to passgrant_type,client_id,client_secret, andaudience. Is there a way to make this work?
Because of these reasons, I had to implement my own via fetch(). Here’s what’s in plugin routes:
"path": "my_custom_token_auth",
"url": "https://mydomain.com/oauth/token"
And here’s the request I’m passing to fetch():
method: ‘POST’,
url: this.instanceSettings.url + ‘/my_custom_token_auth’,
headers: {
‘Content-Type’: ‘application/json’, // this works, it does post JSON
‘Accept’: ‘/’,
data: {
grant_type: ‘client_credentials’,
client_id: ‘{{ .SecureJsonData.clientId }}’,
client_secret: ‘{{ .SecureJsonData.clientSecret }}’,
audience: ‘https://api.mydomain.com’, // here’s that custom audience thing I mentioned
When I pass an explicit clientId and clientSecret, it works perfectly. But as you see it above, with {{ .SecureJsonData.clientSecret }} inside data, that value isn’t getting substituted by the proxy.
I have a feeling I just need to build a backend plugin, but I’d rather not if there’s an alternative. Please let me know – thanks in advance!
