Hi all. I follow “Add authentication for data source plugins” guide, it says I can specify tokenAuth for proxy route in plugin.json. How does it work? What flags should be ON for this feature? withCredentials or basicAuth - should they be ON or OFF? I wish this tokenAuth endpoint could login with email/password on the third side server, receive auth cookie from there and save it in secureJsonData.apiToken, so then it could be automatically used for Authorization: Bearer [apiToken] header.
I have this configs in my plugin.js. Right now if I have no pre-saved apiToken, all my requests fall with 401. What is wrong with it?:
"path": "grafanaproxy",
"url": "https://example.com",
"headers": [
"name": "Authorization",
"content": "Bearer {{ .SecureJsonData.apiToken }}"
"name": "Content-Type",
"content": "application/json"
"tokenAuth": {
"url": "https://example.com/signin",
"params": {
"grant_type": "client_credentials",
"email": "{{ .JsonData.email }}",
"password": "{{ .SecureJsonData.password }}"
