Grafana V7.2 and Windows -
Requirement is to Trigger the alert if two conditions satisfies.
Condition 1: If it reaches threshold, check the condition 2
Condition 2: Check the table whether any records exists between the timeframe.if yes, send the email -
Tried to define Query A and Query B. Query A is the graph and On Query B creates the Oracle Query to read the data from the table.
ex., select column1 from table 1 where $_timefrom >= dateFrom and $_timeto < dateTo
- What happened?
- Template variable is not supported error coming up
Two condition to be satisfied to send alert
