Hi mates,
I have trouble displaying/transforming data to show in a table on a dashboard.
latest from Docker, infinity-datasource plugin v1.4.1 -
given following xml structure, I need to get the value of ‘VALUE’ for each ‘entry’ and display the result of this in the columns ‘value1’,‘value2’ and ‘value3’
<?xml version="1.0" encoding="utf-8"?>
<feed>
<id>1</id>
<entry>
<id>1</id>
<content type="application/xml">
<m:properties>
<d:ID>2078</d:ID>
<d:TASK_GUID></d:TASK_GUID>
<d:VALUE>1;2;3</d:VALUE>
<d:OPERATION>0</d:OPERATION>
</m:properties>
</content>
</entry>
<entry>
<id>2</id>
<m:properties>
<d:ID>2079</d:ID>
<d:VALUE>4;5;6</d:VALUE>
</m:properties>
</content>
</entry>
</feed>
- How are you trying to achieve it?
I am using the infinity-datasource plugin to retrieve the XML via https. Using the backend parser, I can get the ‘VALUE’ field, but end up with one column ‘VALUE’ on my table that contains the string ‘1;2;3’
Using UQL I am not able at all to retrieve any information, due to a lack of understanding and missing examples (only ones I found were for json).
Also, I looked at transformations but was also unable to find a solution for this task.
Is there a way to achieve this result at all?
Thanks!
