Hey,
I’ve been trying to configure grafana in a docker swarm configuration for the past 3 hours I can’t figure it out. The idea is that I manage my vps with bunch of service all in a docker swarm managed with docker stack, and everything is behind a reverse proxy traefik. And this is the configuration for my file with traefik and grafana
services:
reverse-proxy:
image: traefik:v3.3
command:
- "--api.dashboard=true"
- "--log.level=DEBUG"
- "--accesslog.format=json"
- "--providers.docker"
- "--providers.docker.exposedbydefault=false"
- "--entryPoints.websecure.address=:443"
- "--certificatesresolvers.myresolver.acme.tlschallenge=true"
- "--certificatesresolvers.myresolver.acme.email=pro@example.dev"
- "--certificatesresolvers.myresolver.acme.storage=/letsencrypt/acme.json"
- "--entryPoints.web.address=:80"
- "--entryPoints.web.http.redirections.entrypoint.to=websecure"
- "--entryPoints.web.http.redirections.entrypoint.scheme=https"
- "--providers.file.watch=true"
- "--entryPoints.metrics.address=:9100"
- "--metrics.prometheus=true"
- "--metrics.prometheus.entryPoint=metrics"
labels:
- "traefik.enable=true"
- "traefik.http.routers.traefik.entrypoints=websecure"
- "traefik.http.routers.traefik.tls.certresolver=myresolver"
- "traefik.http.routers.traefik.rule=Host(`traefik.example.dev`)"
- "traefik.http.routers.traefik.service=api@internal"
- "traefik.http.middlewares.traefik-auth.basicauth.users=admin:[REDACTED]"
- "traefik.http.routers.traefik.middlewares=traefik-auth"
deploy:
update_config:
order: start-first
ports:
- mode: host
protocol: tcp
published: 80
target: 80
- mode: host
protocol: tcp
published: 443
target: 443
- mode: host
protocol: tcp
published: 9100
target: 9100
extra_hosts:
- "host.docker.internal:host-gateway"
volumes:
- letsencrypt:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock
networks:
- traefik
loki:
image: grafana/loki:3.4.2
command:
- "-config.file=/loki/loki_config.yml"
configs:
- source: loki_config
target: /loki/loki_config.yml
volumes:
- loki-data:/loki
ports:
- mode: host
protocol: tcp
published: 3100
target: 3100
networks:
- traefik
promtail:
image: grafana/promtail:3.4.2
command:
- "-client.url=http://loki:3100/loki/api/v1/push"
- "-config.file=/etc/promtail/config.yml"
volumes:
# Inline config as a volume with a string (minimal config)
- type: tmpfs
target: /etc/promtail
tmpfs:
size: 1000000 # 1MB, sufficient for small config
configs:
- source: promtail_config
target: /etc/promtail/config.yml
deploy:
mode: global
networks:
- traefik
prometheust:
image: prom/prometheus:v3.2.1
volumes:
- prometheus-data:/prometheus
- type: tmpfs
target: /etc/prometheus
tmpfs:
configs:
- source: prometheus_config
target: /etc/prometheus/prometheus.yml
command:
- "--config.file=/etc/prometheus/prometheus.yml"
- "--storage.tsdb.path=/prometheus"
- "--web.enable-lifecycle"
ports:
- mode: host
protocol: tcp
published: 9090
target: 9090
networks:
- traefik
grafana:
image: grafana/grafana:11.5.2
environment:
- GF_AUTH_ANONYMOUS_ENABLED=false
- GF_SECURITY_ADMIN_USER=admin
- GF_SECURITY_ADMIN_PASSWORD__FILE=/run/secrets/grafana-password
- GF_DATASOURCES_PROMETHEUS_URL=http://prometheus:9090
- GF_DATASOURCES_LOKI_URL=http://loki:3100
- GF_SERVER_ROOT_URL=https://dashboard.example.dev/
- GF_SERVER_DOMAIN=dashboard.example.dev
- GF_SERVER_SERVE_FROM_SUB_PATH=false
ports:
- mode: host
protocol: tcp
published: 3000
target: 3000
networks:
- traefik
labels:
- "traefik.http.routers.dashboard.entrypoints=websecure"
- "traefik.http.routers.dashboard.tls.certresolver=myresolver"
- "traefik.http.routers.dashboard.rule=Host(`dashboard.example.dev`)"
- "traefik.http.services.grafana.loadbalancer.server.port=3000"
secrets:
- grafana-password
volumes:
letsencrypt:
loki-data:
prometheus-data:
networks:
traefik:
external: true
secrets:
grafana-password:
external: true
configs:
promtail_config:
file: ./promtail_config.yml
prometheus_config:
file: ./prometheus_config.yml
loki_config:
file: ./loki_config.yml
With this configuration, the problem is that I keep getting redirect, and reach a too many redirect error when I try to go the main page dashboard.example.dev after login. And the redirect happen between / and /login. I tried with anonymous login or password in clear instead of docker secret, but same result.
What is wrong with this config ?
