Hey guys. I am pretty sure there are several of these questions all over the internet. However I could no find any one solution. I am running Docker Swarm, and it has the following configuration.
I have many other services running similarly and they are all being proxied successfully by Traefik. Does Grafana have any special config besides the ones described here?
In the logs of grafana I am not getting any errors, but I am getting this info on the http server
With this configuration I am getting a blank page stating Internal Server Error.
version: '3.8'
networks:
proxy:
external: true
services:
traefik:
image: 'traefik'
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
- ./traefik_logs:/var/log
networks:
- proxy
command:
- --api
- --ping # enable healthchecking
- --providers.docker=true
- --providers.docker.exposedbydefault=false
- --providers.docker.network=proxy
- --providers.docker.swarmMode=true
- --serversTransport.insecureSkipVerify=true # just for portainer
- --entrypoints.web.address=:80
- --entrypoints.web.http.redirections.entryPoint.to=websecure
- --entrypoints.web.http.redirections.entryPoint.scheme=https
- --entrypoints.websecure.address=:443
- --log=true
- --log.format=json
- --log.level=DEBUG
- --log.filepath=/var/log/traefik.log
- --accesslog=true
- --accesslog.filepath=/var/log/access.log
- --accesslog.format=json
- --metrics.prometheus=true
- --entryPoints.metrics.address=:8082
- --metrics.prometheus.entryPoint=metrics
- --tracing.jaeger=true
ports:
- 80:80 # http
- 443:443 # https entrypoint
deploy:
labels:
traefik.enable: 'true'
traefik.http.routers.api.rule: Host(`traefik.${DOMAIN}`)
traefik.http.routers.api.service: api@internal
traefik.http.routers.api.tls: 'true'
# swarm mode discovery
traefik.http.services.traefik.loadbalancer.server.port: 80
placement:
constraints:
- node.role == manager
grafana:
# https://grafana.com/docs/grafana/latest/administration/configure-docker/
image: grafana/grafana-oss
networks:
- proxy
ports:
- '3000:3000'
# https://grafana.com/docs/grafana/next/setup-grafana/configure-grafana/#override-configuration-with-environment-variables
environment:
GF_INSTALL_PLUGINS: "grafana-clock-panel,grafana-simple-json-datasource"
GF_SECURITY_ADMIN_PASSWORD: ${GRAFANA_SECURITY_ADMIN_PASSWORD}
GF_SERVER_DOMAIN: grafana.${DOMAIN}
GF_SERVER_ROOT_URL: https://grafana.${DOMAIN}
GF_USERS_ALLOW_SIGN_UP: 'false'
deploy:
labels:
traefik.http.routers.grafana_rtr.rule: Host(`grafana.${DOMAIN}`)
traefik.http.routers.grafana_rtr.tls: 'true'
traefik.http.routers.grafana_rtr.service: grafana
traefik.http.services.grafana.loadbalancer.server.port: 3000
traefik.http.services.grafana.loadbalancer.server.scheme: https
traefik.docker.network: proxy
