After upgrading Grafana Alloy to v1.11.3 latest version trace exports to Tempo started failing with the following error message:
level=info msg="Exporting failed. Will retry the request after interval." component_path=/ component_id=otelcol.exporter.otlphttp.traces error="failed to make an HTTP request: Post \"https://$tempo-endpoint/v1/traces\": net/http: HTTP/1.x transport connection broken: malformed HTTP response"
The Grafana Alloy is inside of kubernetes cluster and working with ingress-nginx.
Grafana Alloy current version: v1.10.1
Helm chart Grafana Allow version: 1.2.1
Grafana Tempo version: 2.8.2
Helm chart Grafana Tempo version: 1.48.1
Config:
otelcol.receiver.otlp "otlp_receiver" {
grpc {
endpoint = "0.0.0.0:4317"
output {
traces = [otelcol.processor.batch.default.input]
// traces = [otelcol.exporter.otlphttp.traces.input]
// traces = [otelcol.exporter.otlphttp.traces.input,otelcol.connector.servicegraph.servicegraph.input]
otelcol.processor.batch "default" {
send_batch_size = 8192
send_batch_max_size = 0
output {
otelcol.exporter.otlphttp "traces" {
client {
endpoint = "$tempo-endpoint"
tls {
insecure = true
insecure_skip_verify = true
auth = otelcol.auth.basic.tempo_auth.handler
