I am trying to use Grafana Alloy with Grafana Beyla enabled and hope it can send some traces to Grafana Tempo.
With this setup, Alloy succeed sending logs to Loki. However, for traces, I cannot see any traces in Grafana and also no Service Graph. Stuck here for days. And I didn’t see any useful logs. Any guide would be appreciate, thank you! ![]()
Helm Charts:
Grafana
apiVersion: argoproj.io/v1alpha1
kind: Application
metadata:
namespace: production-hm-argo-cd
labels:
app.kubernetes.io/name: hm-grafana
spec:
project: production-hm
sources:
- repoURL: https://grafana.github.io/helm-charts
# https://artifacthub.io/packages/helm/grafana/grafana
targetRevision: 8.8.5
chart: grafana
helm:
releaseName: hm-grafana
values: |
# https://github.com/grafana/helm-charts/blob/main/charts/grafana/values.yaml
sidecar:
dashboards:
enabled: true
searchNamespace: ALL
datasources:
datasources.yaml:
apiVersion: 1
datasources:
- name: hm-prometheus
type: prometheus
isDefault: true
url: http://hm-prometheus-kube-pr-prometheus.production-hm-prometheus:9090
access: proxy
- name: hm-loki
type: loki
isDefault: false
url: http://hm-loki-gateway.production-hm-loki:80
access: proxy
- name: hm-tempo
type: tempo
isDefault: false
url: http://hm-tempo-query-frontend.production-hm-tempo:3100
access: proxy
# https://grafana.com/docs/grafana/next/datasources/tempo/configure-tempo-data-source/#example-file
jsonData:
tracesToLogsV2:
datasourceUid: 'hm-loki'
spanStartTimeShift: '-1h'
spanEndTimeShift: '1h'
tags: ['job', 'instance', 'pod', 'namespace']
filterByTraceID: false
filterBySpanID: false
customQuery: true
query: 'method="$${__span.tags.method}"'
tracesToMetrics:
datasourceUid: 'hm-prometheus'
tags: [{ key: 'service.name', value: 'service' }, { key: 'job' }]
queries:
- name: 'Sample query'
query: 'sum(rate(traces_spanmetrics_latency_bucket{$$__tags}[5m]))'
serviceMap:
nodeGraph:
enabled: true
search:
hide: false
traceQuery:
timeShiftEnabled: true
spanBar:
type: 'Tag'
tag: 'http.path'
streamingEnabled:
search: true
- repoURL: git@github.com:hongbo-miao/hongbomiao.com.git
targetRevision: main
path: kubernetes/argo-cd/applications/production-hm/grafana/kubernetes-manifests
destination:
namespace: production-hm-grafana
server: https://kubernetes.default.svc
syncPolicy:
syncOptions:
- ServerSideApply=true
automated:
prune: true
Tempo
kind: Application
metadata:
labels:
app.kubernetes.io/name: hm-tempo
spec:
source:
# https://artifacthub.io/packages/helm/grafana/tempo-distributed
targetRevision: 1.31.0
chart: tempo-distributed
helm:
releaseName: hm-tempo
values: |
# https://github.com/grafana/helm-charts/blob/main/charts/tempo-distributed/values.yaml
# https://grafana.com/docs/tempo/latest/setup/operator/object-storage/
tempo:
structuredConfig:
# https://grafana.com/docs/tempo/latest/traceql/#stream-query-results
stream_over_http_enabled: true
gateway:
enabled: false
serviceAccount:
create: true
annotations:
eks.amazonaws.com/role-arn: arn:aws:iam::272394222652:role/TempoRole-hm-tempo
storage:
admin:
backend: s3
s3:
endpoint: s3.amazonaws.com
region: us-west-2
bucket: production-hm-tempo-admin-bucket
trace:
backend: s3
s3:
region: us-west-2
bucket: production-hm-tempo-trace-bucket
traces:
otlp:
http:
enabled: true
grpc:
enabled: true
metricsGenerator:
enabled: true
config:
processor:
# https://grafana.com/docs/tempo/latest/operations/traceql-metrics/
local_blocks:
filter_server_spans: false
storage:
remote_write:
- url: http://hm-prometheus-kube-pr-prometheus.production-hm-prometheus:9090/api/v1/write
global_overrides:
metrics_generator_processors:
- local-blocks
- service-graphs
- span-metrics
destination:
namespace: production-hm-tempo
syncPolicy:
syncOptions:
automated:
prune: true
Alloy
kind: Application
metadata:
labels:
app.kubernetes.io/name: hm-alloy
spec:
source:
# https://artifacthub.io/packages/helm/grafana/alloy
targetRevision: 0.11.0
chart: alloy
helm:
releaseName: hm-alloy
values: |
# https://github.com/grafana/alloy/blob/main/operations/helm/charts/alloy/values.yaml
alloy:
# For "beyla.ebpf", see https://grafana.com/docs/grafana-cloud/send-data/alloy/reference/components/beyla/beyla.ebpf/
stabilityLevel: public-preview
extraEnv:
- name: LOKI_URL
value: http://hm-loki-gateway.production-hm-loki:80/loki/api/v1/push
- name: TEMPO_ENDPOINT
value: hm-tempo-distributor.production-hm-tempo:4317
configMap:
content: |-
// https://grafana.com/docs/alloy/latest/configure/kubernetes/
// https://grafana.com/docs/alloy/latest/collect/logs-in-kubernetes/
logging {
level = "info"
format = "logfmt"
// local.file_match discovers files on the local filesystem using glob patterns and the doublestar library. It returns an array of file paths.
local.file_match "node_logs" {
path_targets = [{
// Monitor syslog to scrape node-logs
__path__ = "/var/log/syslog",
job = "node/syslog",
node_name = sys.env("HOSTNAME"),
cluster = "hm-eks-cluster",
// loki.source.file reads log entries from files and forwards them to other loki.* components.
// You can specify multiple loki.source.file components by giving them different labels.
loki.source.file "node_logs" {
targets = local.file_match.node_logs.targets
forward_to = [loki.write.default.receiver]
// discovery.kubernetes allows you to find scrape targets from Kubernetes resources.
// It watches cluster state and ensures targets are continually synced with what is currently running in your cluster.
discovery.kubernetes "pod" {
role = "pod"
// discovery.relabel rewrites the label set of the input targets by applying one or more relabeling rules.
// If no rules are defined, then the input targets are exported as-is.
discovery.relabel "pod_logs" {
targets = discovery.kubernetes.pod.targets
// Label creation - "namespace" field from "__meta_kubernetes_namespace"
rule {
source_labels = ["__meta_kubernetes_namespace"]
action = "replace"
target_label = "namespace"
// Label creation - "pod" field from "__meta_kubernetes_pod_name"
rule {
source_labels = ["__meta_kubernetes_pod_name"]
action = "replace"
target_label = "pod"
// Label creation - "container" field from "__meta_kubernetes_pod_container_name"
rule {
source_labels = ["__meta_kubernetes_pod_container_name"]
action = "replace"
target_label = "container"
// Label creation - "app" field from "__meta_kubernetes_pod_label_app_kubernetes_io_name"
rule {
source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_name"]
action = "replace"
target_label = "app"
// Label creation - "job" field from "__meta_kubernetes_namespace" and "__meta_kubernetes_pod_container_name"
// Concatenate values __meta_kubernetes_namespace/__meta_kubernetes_pod_container_name
rule {
source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_container_name"]
action = "replace"
target_label = "job"
separator = "/"
replacement = "$1"
// Label creation - "container" field from "__meta_kubernetes_pod_uid" and "__meta_kubernetes_pod_container_name"
// Concatenate values __meta_kubernetes_pod_uid/__meta_kubernetes_pod_container_name.log
rule {
source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
action = "replace"
target_label = "__path__"
separator = "/"
replacement = "/var/log/pods/*$1/*.log"
// Label creation - "container_runtime" field from "__meta_kubernetes_pod_container_id"
rule {
source_labels = ["__meta_kubernetes_pod_container_id"]
action = "replace"
target_label = "container_runtime"
regex = "^(\\S+):\\/\\/.+$"
replacement = "$1"
// loki.source.kubernetes tails logs from Kubernetes containers using the Kubernetes API.
loki.source.kubernetes "pod_logs" {
targets = discovery.relabel.pod_logs.output
forward_to = [loki.process.pod_logs.receiver]
// loki.process receives log entries from other Loki components, applies one or more processing stages,
// and forwards the results to the list of receivers in the component's arguments.
loki.process "pod_logs" {
stage.static_labels {
values = {
// loki.source.kubernetes_events tails events from the Kubernetes API and converts them
// into log lines to forward to other Loki components.
loki.source.kubernetes_events "cluster_events" {
job_name = "integrations/kubernetes/eventhandler"
log_format = "logfmt"
forward_to = [
loki.process.cluster_events.receiver,
// loki.process receives log entries from other loki components, applies one or more processing stages,
loki.process "cluster_events" {
values = {
stage.labels {
values = {
kubernetes_cluster_events = "job",
loki.write "default" {
endpoint {
url = env("LOKI_URL")
// https://grafana.com/docs/tempo/latest/configuration/grafana-alloy/automatic-logging/
// https://grafana.com/docs/tempo/latest/configuration/grafana-alloy/service-graphs/
// https://grafana.com/docs/tempo/latest/configuration/grafana-alloy/span-metrics/
// https://grafana.com/blog/2024/05/21/how-to-use-grafana-beyla-in-grafana-alloy-for-ebpf-based-auto-instrumentation/
beyla.ebpf "default" {
attributes {
kubernetes {
enable = "true"
discovery {
services {
exe_path = "http"
open_ports = "80"
output {
traces = [otelcol.processor.batch.default.input]
otelcol.receiver.otlp "default" {
grpc {}
http {}
output {
metrics = [otelcol.processor.batch.default.input]
logs = [otelcol.processor.batch.default.input]
traces = [
otelcol.connector.servicegraph.default.input,
otelcol.connector.spanlogs.default.input,
otelcol.connector.spanmetrics.default.input,
otelcol.connector.servicegraph "default" {
dimensions = ["http.method", "http.target"]
output {
otelcol.connector.spanlogs "default" {
roots = true
output {
otelcol.connector.spanmetrics "default" {
dimension {
name = "http.method"
default = "GET"
dimension {
name = "http.target"
aggregation_temporality = "DELTA"
histogram {
explicit {
buckets = ["50ms", "100ms", "250ms", "1s", "5s", "10s"]
metrics_flush_interval = "15s"
namespace = "traces_spanmetrics"
output {
otelcol.processor.batch "default" {
output {
metrics = [otelcol.exporter.otlp.hm_tempo.input]
logs = [otelcol.exporter.otlp.hm_tempo.input]
traces = [otelcol.exporter.otlp.hm_tempo.input]
otelcol.exporter.otlp "hm_tempo" {
client {
endpoint = env("TEMPO_ENDPOINT")
tls {
insecure = true
insecure_skip_verify = true
destination:
namespace: production-hm-alloy
syncPolicy:
syncOptions:
automated:
prune: true
Alloy’s graph
All are healthy:
Logs
One of alloy pods log
It is long, I put at Alloy log · GitHub
I saw a line
2025/01/30 08:59:35 ERROR Unable to load eBPF watcher for process events component=discover.ProcessWatcher interval=5s error=“loading and assigning BPF objects: field BeylaKprobeSysBind: program beyla_kprobe_sys_bind: map watch_events: map create: operation not permitted (MEMLOCK may be too low, consider rlimit.RemoveMemlock)”
inside, however, I am not sure how to resolve. I am using Amazon EKS.
I expect that other traces might be appearing in Grafana, even those traces from Beyla not function properly. (I could be wrong)
tempo-distributor pod log
level=warn ts=2025-01-30T06:36:10.194320099Z caller=main.go:133 msg="-- CONFIGURATION WARNINGS --"
level=warn ts=2025-01-30T06:36:10.19437038Z caller=main.go:139 msg="Inline, unscoped overrides are deprecated. Please use the new overrides config format."
level=info ts=2025-01-30T06:36:10.197225405Z caller=main.go:121 msg="Starting Tempo" version="(version=v2.7.0, branch=HEAD, revision=b0da6b481)"
level=info ts=2025-01-30T06:36:10.197899194Z caller=server.go:248 msg="server listening on addresses" http=[::]:3100 grpc=[::]:9095
ts=2025-01-30T06:36:10Z level=info msg="OTel Shim Logger Initialized" component=tempo
level=info ts=2025-01-30T06:36:10.413004915Z caller=memberlist_client.go:446 msg="Using memberlist cluster label and node name" cluster_label=hm-tempo.production-hm-tempo node=hm-tempo-distributor-6f579f694c-665x8-51b758e5
level=info ts=2025-01-30T06:36:10.414030557Z caller=module_service.go:82 msg=starting module=internal-server
level=info ts=2025-01-30T06:36:10.414226259Z caller=module_service.go:82 msg=starting module=server
level=info ts=2025-01-30T06:36:10.414342161Z caller=module_service.go:82 msg=starting module=memberlist-kv
level=info ts=2025-01-30T06:36:10.414361461Z caller=module_service.go:82 msg=starting module=overrides
level=info ts=2025-01-30T06:36:10.414402831Z caller=module_service.go:82 msg=starting module=ring
level=info ts=2025-01-30T06:36:10.414436302Z caller=module_service.go:82 msg=starting module=metrics-generator-ring
level=info ts=2025-01-30T06:36:10.414457312Z caller=module_service.go:82 msg=starting module=usage-report
level=warn ts=2025-01-30T06:36:10.414641774Z caller=runtime_config_overrides.go:97 msg="Overrides config type mismatch" err="per-tenant overrides config type does not match static overrides config type" config_type=new static_config_type=legacy
level=error ts=2025-01-30T06:36:10.498151365Z caller=resolver.go:87 msg="failed to lookup IP addresses" host=hm-tempo-gossip-ring err="lookup hm-tempo-gossip-ring on 10.215.0.10:53: no such host"
level=warn ts=2025-01-30T06:36:10.498190246Z caller=resolver.go:134 msg="IP address lookup yielded no results. No host found or no addresses found" host=hm-tempo-gossip-ring
level=info ts=2025-01-30T06:36:10.498203496Z caller=memberlist_client.go:563 msg="memberlist fast-join starting" nodes_found=0 to_join=0
level=warn ts=2025-01-30T06:36:10.498217166Z caller=memberlist_client.go:583 msg="memberlist fast-join finished" joined_nodes=0 elapsed_time=83.858295ms
level=info ts=2025-01-30T06:36:10.498238626Z caller=memberlist_client.go:595 phase=startup msg="joining memberlist cluster" join_members=dns+hm-tempo-gossip-ring:7946
level=info ts=2025-01-30T06:36:10.498317557Z caller=ring.go:316 msg="ring doesn't exist in KV store yet"
level=info ts=2025-01-30T06:36:10.498360498Z caller=ring.go:316 msg="ring doesn't exist in KV store yet"
level=info ts=2025-01-30T06:36:10.498495459Z caller=module_service.go:82 msg=starting module=distributor
ts=2025-01-30T06:36:10Z level=warn msg="Using the 0.0.0.0 address exposes this server to every network interface, which may facilitate Denial of Service attacks." component=tempo documentation=https://github.com/open-telemetry/opentelemetry-collector/blob/main/docs/security-best-practices.md#safeguards-against-denial-of-service-attacks
ts=2025-01-30T06:36:10Z level=info msg="Starting GRPC server" component=tempo endpoint=0.0.0.0:4317
ts=2025-01-30T06:36:10Z level=info msg="Starting HTTP server" component=tempo endpoint=0.0.0.0:4318
level=info ts=2025-01-30T06:36:10.498914304Z caller=app.go:208 msg="Tempo started"
level=error ts=2025-01-30T06:36:10.509656008Z caller=resolver.go:87 msg="failed to lookup IP addresses" host=hm-tempo-gossip-ring err="lookup hm-tempo-gossip-ring on 10.215.0.10:53: no such host"
level=warn ts=2025-01-30T06:36:10.509682688Z caller=resolver.go:134 msg="IP address lookup yielded no results. No host found or no addresses found" host=hm-tempo-gossip-ring
level=warn ts=2025-01-30T06:36:10.509699598Z caller=memberlist_client.go:629 phase=startup msg="joining memberlist cluster" attempts=1 max_attempts=10 err="found no nodes to join"
level=error ts=2025-01-30T06:36:11.536326569Z caller=resolver.go:87 msg="failed to lookup IP addresses" host=hm-tempo-gossip-ring err="lookup hm-tempo-gossip-ring on 10.215.0.10:53: no such host"
level=warn ts=2025-01-30T06:36:11.536359541Z caller=resolver.go:134 msg="IP address lookup yielded no results. No host found or no addresses found" host=hm-tempo-gossip-ring
level=warn ts=2025-01-30T06:36:11.53637399Z caller=memberlist_client.go:629 phase=startup msg="joining memberlist cluster" attempts=2 max_attempts=10 err="found no nodes to join"
level=error ts=2025-01-30T06:36:15.080790386Z caller=resolver.go:87 msg="failed to lookup IP addresses" host=hm-tempo-gossip-ring err="lookup hm-tempo-gossip-ring on 10.215.0.10:53: no such host"
level=warn ts=2025-01-30T06:36:15.080823057Z caller=resolver.go:134 msg="IP address lookup yielded no results. No host found or no addresses found" host=hm-tempo-gossip-ring
level=warn ts=2025-01-30T06:36:15.080835127Z caller=memberlist_client.go:629 phase=startup msg="joining memberlist cluster" attempts=3 max_attempts=10 err="found no nodes to join"
level=info ts=2025-01-30T06:36:19.988200041Z caller=memberlist_client.go:602 phase=startup msg="joining memberlist cluster succeeded" reached_nodes=7 elapsed_time=9.489949855s
