Hi !
Using Grafana v10.2.1
I’m graphing a time series and wanted to add a data link to the tool tip. But it looks like the ${__data.fields}
and ${__value}
variables are not populating the same way as the tooltip itself does.
I’m using the Data links section of the Time Series panel with variables.
In the screenshot, the tooltip is for the point at 2023-11-30 23:04:29
for the value 636
, but the value used for variable ${__data.fields.Dataset}
is 2023-11-05 02:04:05
and ${__value.text}
is 98
and I’m not sure why.
I would expect it to be the same as the Tooltip’s values for both axis.
Source is a simple Postgresql query SELECT ts, COUNT(*) ...
and in table view, data looks accurate. I do not use the build-in time range.
Would you happen to know what I’m doing wrong and how I could solve this?
