Loki version is loki-windows-amd64.exe / Grafana v12.0.1+security-01 / Windows Server 2022 Standard - What are you trying to achieve?
when i add more panels on dashboard the panel does not load and give “too many outstanding requests” - How are you trying to achieve it?
i tried with multiple different setting on loki-config.yaml , query , caching , timeout , etc. I have not tried to change schema version - What happened?
- the issue still not resolved.
-to be able to add multiple panels on dashboard - Can you copy/paste the configuration(s) that you are having problems with?
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9095
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
max_chunk_age: 1h
chunk_target_size: 1048576
chunk_retain_period: 30s
wal:
enabled: true
dir: C:\loki\wal
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: C:\loki\index
cache_location: C:\loki\boltdb-cache
shared_store: filesystem
filesystem:
directory: C:\loki\chunks
ADD THIS COMPARTOR SECTION
compactor:
working_directory: C:\loki\compactor
limits_config:
enforce_metric_name: false
reject_old_samples: true
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: true
retention_period: 168h
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- the dashboard panel showing symbol “too many outstanding requests”. attached screenshot
- Did you follow any online instructions? If so, what is the URL?
Too many outstanding requests on loki 2.7.1
