Hi everyone,
I have a jks with certificates and keys. How can i change the certificates and keys on runtime under test?
Thanks and best regards,
Samer
Hi everyone,
Samer
I am not sure exactly what you are trying to do and I have never used a Java KeyStore (which is what I assume JKS stands for), sorry.
However, if your goal is to use different client-side TLS certificates for different HTTPS requests, then unfortunately that is not currently possible with k6 The only way to currently specify client-side certificates is the global
tlsAuth
option you’ve already mentioned. There is currently no way to specify different certificates during the runtime of a k6 test
It’s a limitation to the current k6/http
API that we’d like to change, follow these issues for updates:
