Encrypted tls certificate support in k6
I am new to k6, and trying to create load test, which would use encrypted tls (pkcs12 or pkcs8)certificate. Currently I am receiving different error messages and after reading through this topic Support for encrypted PKCS8 or PKCS12 private keys · Issue #2834 · grafana/k6 · GitHub
I understand that only unencrypted tls is supported. Can someone tell me if the situation is still the same?
Hi @myousamurai
Apologies for the delay in getting back to you; this has gone under my radar. Depending on your needs, you might be able to leverage the Webcrypto module, which has (incomplete) support for the Webcrypto API specification and its operations/algorithms.
:bowing_man:
