What Grafana version and what operating system are you using? RHEL8 and the Grafana version is 9.5.2
What are you trying to achieve? - Trying to connect to Azure Monitor from on-premise Grafana
How are you trying to achieve it? From Grafana Dashboards
What happened? - We can add the Datasource, but when we try to test it , it fails with below error… 2. Error connecting to Azure Log Analytics endpoint: health check failed: Post “https://api.loganalytics.io/v1/workspaces/xxxxxxxx/query”: tls: failed to verify certificate: x509: certificate signed by unknown authority
What did you expect to happen? - Successful connection without Errors
Can you copy/paste the configuration(s) that you are having problems with? - Please help us on how to add the cacerts to the Grafana configuration or how to Skip the tls verification?
Tried mutiple options by adding the required certs to the trusts.crt file, used tls_insecure_skip_verify=true , root_ca_cert,ca_cert parameter. none of them are taken as truststore in the defaults.ini file? -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - in the grafana console
Did you follow any online instructions? If so, what is the URL? there is no concrete information provided in the URL we gone through on where and what to add to skip the SSL verification or what parameter to add for the cacerts addition to the defaults.ini file
You need to update CA certificates in your OS. Check your OS for more detaild.
BTW: RHEL8 has reached end of life, so you may have a problem with that.
Thank you @jangaraj and is there an option to use in grafana(defaults.ini file) the Customized Trust Store instead of system wide? Like how we have for LDAP connectivity( in ldap.toml) file?
No, Grafana is Golang app, so ask how golang can use “trust store”.
Golang on linux - The Go Programming Language is trying to find “trust store” in this order:
// Possible certificate files; stop after finding one.
var certFiles = []string{
"/etc/ssl/certs/ca-certificates.crt", // Debian/Ubuntu/Gentoo etc.
"/etc/pki/tls/certs/ca-bundle.crt", // Fedora/RHEL 6
"/etc/ssl/ca-bundle.pem", // OpenSUSE
"/etc/pki/tls/cacert.pem", // OpenELEC
"/etc/pki/ca-trust/extracted/pem/tls-ca-bundle.pem", // CentOS/RHEL 7
"/etc/ssl/cert.pem", // Alpine Linux
// Possible directories with certificate files; all will be read.
var certDirectories = []string{
"/etc/ssl/certs", // SLES10/SLES11, https://golang.org/issue/12139
"/etc/pki/tls/certs", // Fedora/RHEL
So use that to “hack” it.
Oh got it… this is great information… thanks a lot @jangaraj
