I created a dashboard using a calculated metric ticket.timestamp_created - ticket.timestamp_reported
via StatsD. When comparing against the same metric in my psql DB, there are marked differences.
- All time diffs are below 15m, which does not line up with what’s showing on Grafana
- Grafana/Graphite is showing fewer than the number of data points (1 data point) compared with DB (3 data points)
- timestamp on Grafana has a massive delay vs timestamp_created (would expect a couple seconds but looks to be ~2 mins delay)
![Screenshot from 2020-05-19 18-03-29](https://us1.discourse-cdn.com/grafana/original/2X/c/c589a86608c68909ff9063c65a426ab02dd7cdb4.png)
[left] psql DB; top 3 entries correspond (probably) to Grafana graph cursor
[right] Grafana dashboard; note cursor time diff is significantly higher than DB, also note only 1 data point vs 3 data points
[bottom] Graphite query response, showing only 1 data point
For ref, this is the metric is being captured/sent via StatsD
AppEnv.stats.timing( 'dp.auto_action_transition.811_to_ticket', ticket.timestamp_created - ticket.timestamp_reported, )
Any idea what’s going on here or an alternative approach? Thanks!!!
