V9.4.7, Home Assistant Operating System (running Grafana as add-on) -
Read a MariaDb database table and group values by time (1d / 1h). My sql worked until the underlying structure of the table changed. The original grouping column (created) was of type datetime(6) and then a new column (created_ts) was added of type double. This original column’s values were all changed to null and the new column became unix time (e.g. 1681124411.7901478). Here is an example of a query that worked before the table change:
SELECT
$__timeGroupAlias(created,1d),
state AS "Grid"
FROM homeassistant.statistics
WHERE
metadata_id = 168
GROUP BY 1
ORDER BY $__timeGroup(created,1d)
Because the original column now had null values, this obviously only return 1 row.
I tried the original query above, but used the new column, created_ts. Result, again 1 row returned, grouped by null value.
I then tried the following:
SELECT
$__timeGroupAlias(FROM_UNIXTIME(created_ts),1d),
state AS "Grid"
WHERE
metadata_id = 168
GROUP BY 1
ORDER BY 1
and received the following error: interpolation failed: macro __timeGroup needs time column and interval.
To check that the data was valid, I ran the following sql:
SELECT
FROM_UNIXTIME(created_ts) AS "time",
state AS "Grid"
WHERE
metadata_id = 168
GROUP BY 1
ORDER BY 1
and multiple rows were returned ok.
FROM_UNIXTIME(created_ts) Grid
2022-06-20 16:00:11 0.400
What happened?
I expected the $__timeGroupAlias macro to be able to interpret the FROM_UNIXTIME result as a valid time column. -
See above sql. -
I would appreciate any assistance as I have tried resolving this issue for a while now.
