Hello community,
I have the following table:
The table contains multiple instances, and each instance has a value calculated daily. I want to transform the Time column into the table’s title. I used Grouping by Metrics, and it works as I intended, but the time is displayed as a number (unix time) instead of the format (dd-mm-yyyy…).
Initial tables:
After I use Grouping by Metrics (It seems to be showing a number in Unix timestamp format):
How can I adjust this format?
Thanks
Note: Transform data:
