Time series shift the timestamp for one series
Hello together,
i have a problem about a very specific problem to display the average of the last hour in grafana.
    9.5.1
    data source is influxDB.
    i need the difference between the same value to the same value 1 hour ago but for every minute.
    For example (value at 10:00 - value at 9:00) displayed at 10:00. Next (value at 10:01 - value at 9:01) displayed at 10:01 o’clock
  • i tried it with:
    SELECT difference(last(“value”)) FROM (
    SELECT last(“value”) FROM “autogen”.“mqtt_data”
    WHERE (“topic”::tag = ‘VALUE/VERSORGUNG/OSMOSEANLAGE/KWP01_FQ605_X_Nachspeisung_VE-Wasser’) AND $timeFilter
    GROUP BY time(1m) fill(null)
    ) WHERE time >= now() - 1h
  • What happened?
  • got an error: InfluxDB Error: difference aggregate requires a GROUP BY interval
  • for example, at 09.00 my value is 4174,66, hat 08:00 it is 4174,12. My expected result need to be 4174,12-4174,66 = 0,54 and displayed with the timestamp at 9:00.
  • The same for 09:01 and 08:01 o’clock
  • If needed i can post the complete JSON of the panel.
  • InfluxDB Error: difference aggregate requires a GROUP BY interval
  • chatgpt ;).
Thanks for your effort!
