Time Series: how to use column values as serie names
Possible duplicate of 80782.
    v11.6 / Linux
    Use a column data as serie name while keeping all metadata columns available:
    SELECT ts, val, serie, metadata
    FROM data_table
    to be treated by Grafana as
    ts serie 1 serie N metadata
    ts1 val1 NULL metadata1
    ts1 NULL val2 metadata2
    tsM valX NULL metadataX
    Currently I’ve come up with only working solution:
    1. GROUP BY into JSON:
    SELECT ts, json_object_agg(serie, val) as obj, metadata
    FROM data_table
    GROUP BY ts, metadata
    1. Use Extract fields transformation.
  • What happened?
    The downside of the above approach is complication of SQL query - unnecessary GROUP BY and JSON packing/unpacking.
    I’ve also tried another transformations, but all of them have their own downsides:
    • Grouping to matrix - with Column: serie, Row: ts, Cell value: val - it works and allows to show time series grouped by serie names, but it doesn’t preserve metadata column => if I want to create override to form a link for every point on a graph using metadata column, it is not possible with this transformation.
    • Partition by values - it somehow works and even link could be created, but:
      • data is no longer in single table when Inspect -> Data is used.
      • every serie is prefixed with val column name, so I see val serie 1val serie N in the legend.
    Have an option for Time Series panel to auto-group values and metadata by specified column or have transformation that works like Grouping to matrix, but keeps metadata columns connected with values.
    Time series | Grafana documentation
Just profiled 2 variants - with and without json_object_agg, and in my case using this workaround increases query time from 6.5 to 9 seconds. I would say that it is too much, so better to have proper solution in Grafana.
What is your datasource? MSSQL?
PostgreSQL 16
