Grafana v12.0.2 -
Show numerical Prometheus query result in a panel. -
I have a Prometheus query which provides a numerical value (number of x). I use that query in the panel to show the result. -
What happened?
In the View mode (dashboard) I see “No data”. When I edit the panel and it’s loaded, I still see “No data”. But if I wait for the next automatic refresh (5s), than the expected data is shown. Consequent refreshes still show data. But when leaving the edit mode and go back to view mode. On first panel load, the data is shown, but after automatic refresh (5s), the data disapears. -
The query result is consistently shown no matter in which mode the dashboard is in. -
No. -
No. -
No
