Grafana 9.2.0 -
I want to display graphic in Grafana panel based on simple query to VictoriaMetrics. -
Query:
{metric_name="change_dist_reach", method=~".+", method!="0", __name__=~".+test"}
Tried to use different queries.
Another query is just a timeseries without filtering:
psa_clf_change_dist_reach_HistogramBasedOutlierDetector_test
- What happened?
For the second query:
Values should be constant through refreshes. -
No errors. -
I tried to change Min step from auto to values from 1h to 25h, but it didn’t help.
