HI,
How to change the theme dark or light using JSON import
I tried with Grafana default docs also … like { style: " light " }
taking by default dark theme only
help out
thanks in advance
HI,
help out
thanks in advance
Open your config file which you used for the installation . Default or custom . If you have created custom then just search keyword " Theme"
default_theme = dark
You can change the theme dark to light here and after that just restart grafana service.
