My rrd graph is OK, peak at 04h13.
The date on client and server are the same. belgium > CET
berni@server:~ $ date; date +%s
lun 30 déc 2024 11:43:37 CET
1735555417
berni@atelier:~$ date; date +%s
lun 30 déc 2024 11:43:38 CET
1735555418
The time display in grafana is set accordingly, browser time brussels CET UTC+01.
I have other graphs showing the same problem.
Do you need more informations ?
Thanks in advance and have a nice day.
Thanks for your indication. I will surely NOT alter my databases, some are more than 10 years old. If you check my graph, left corner bottom. You will see conso last: 900 this is the good last value. Despite that, the graph is showing a value less than 800 ??? For me no problem I will not use anymore those time graphs and set my alarms on gauge graphs which are giving the good value. rrdtool work perfectly for me, I will so keep it. I also use jpgraph, a very powerfull php graphs generator.
Have a nice last day of the year.
Bernard
Hello everybody, I found a workaround, I added a second date_time field in the Db which contains UTC values and give it to grafana. Just a workaround, not happy with that. Give us a switch or config in grafana to use the data as there are without playing with…
Thanks for the help and Happy Newyear !!!
