The "hosted logs" page generates wrong Loki push API token?
Ship logs from OpenWRT to Grafana Cloud loki instance
Following the instructions for logs under my instance, I tried to follow the “Generate Now” button and the pop-up window to generate an API token to be used by openwrt-loki-exporter to push logs from OpenWRT to Grafana Cloud Loki (it’s a shell script which uses curl to achieve that)
  • What happened?
The pop-up window offers to generate a token with many read access but not the necessary write access:
With this token, the script failed to push logs to Loki, generating the following errors:
curl: (22) The requested URL returned error: 401
POST FAILED: '{"streams": [{"stream": {"job": "openwrt_loki_exporter", "host": "OpenWrt"}, "values": [["1744528214519000000", "daemon.info dnsmasq-dhcp[1]: DHCPACK ..."]]}]}'
I found the list of tokens of my instance under the Access Policies tab and changed the permissions on this token to contain ONLY logs:write (I removed all the previous scopes)
After that, the script started posting the logs successfully and I could see them in a query of Loki.
I’m writing here to suggest that the automatic token generation button be updated to include the logs:write only. It would save time and confusion from future users.
The script should be able to push logs to the Grafana Cloud Loki instance using this token.
