Trying to send a raw http request to loki, and getthing this error “authentication error: invalid scope requested”
This is how I’m forming my request
host: https://username:token@logs-prod-006.grafana.net/loki/api/v1/push
content: some json
headers: { ['Content-Type'] = 'application/json', ["X-Scope-OrgID"] = "my_org_id_in_org_settings"})
Any idea whats going on?
Please remove X-Scope-OrgID header.
Already tried removing it, same issue unfortunately
Please provide reproducible example?
Have reproduced it with curl, using a similar example I found here: prometheus - Send logs directly to Loki without use of agents - Stack Overflow
curl -v -H "Content-Type: application/json" -XPOST -s "https://username:token@logs-prod-006.grafana.net/loki/api/v1/push" --data-raw '{"streams": [{ "stream": { "foo": "bar2" }, "values": [ [ "1570818238000000000", "fizzbuzz" ] ] }]}'
Try:
curl \
-H "Content-Type: application/json" \
-H "Authorization: Bearer username:token" \
-X POST \
-d '{"streams": [{ "stream": { "foo": "bar2" }, "values": [ [ "1570818238000000000", "fizzbuzz" ] ] }]}' \
https://logs-prod-006.grafana.net/loki/api/v1/push
Make sure that you have write permission for used user/token.
Getting the same issue with that curl request you provided
Just to confirm I am getting the username and token from
https://grafana.com/orgs/robcf09/hosted-logs/USERNAME_HERE
There’s just a button generate the token, how do I check it has the correct write permission?
Generate new token and select right scope:
Thank you
My token only had logs read, needed logs write!
How did u get the write perssion? any link to that page?
