Text and amount in the table
I sent the following data to the InfluxDB:
app=foo,value=1
app=foo,value=3
app=bar,value=2
app=bar,value=4
How do I get such a table in Grafana?
app sum(value)
foo 4
bar 6
use table panel, group by app key. remove group by time
Thank you Torkel!
You are right, if I add data to Influx from the command line, then everything works.
InluxDB:
INSERT test,app=foo value=1
INSERT test,app=bar value=2
Grafana:
SELECT sum(“value”) FROM “test” WHERE $timeFilter GROUP BY “app”
grafana
It is not clear how to set the value of the tag (app) in Logstash?
The add_tag filter can only add a tag name without a tag value
I figured out the send_as_tags instruction to solve my problem.
Grafana is a great tool, thanks, Torkel, for your work!
Hi I am very new to Grafana and I am probably missing something. I am finding very difficult to put the same data in to very simple bar chart where each bar would represent the category with values. How can this be done? I am using postgres as my datasource.
Thanks
