Hello, running on Grafana 8.4 & Tempo 1.2.1, we would like to try the promising feature of Tempo Search.
We enable the Feature Toggle tempoSearch tempoBackendSearch in Grafana, and the search functionnality in Helm Chart for Tempo:
search:
# -- Enable Tempo search
enabled: true
When I try to request a Tempo Search, I can see that the fields are populated, but I get 0 Series, but I know we post some traces each minute for this service:
I can see the requests incoming in the Query Frontend:
level=info ts=2022-03-04T16:17:41.73750736Z caller=handler.go:94 tenant=single-tenant method=GET traceID=57e22543b9145f47 url="/api/search?tags=%20service.name%3D%22dsc%3Adsc-insertion-router-aggregator%22&limit=20&start=1646407061&end=1646410661" duration=4.150722ms response_size=78 status=200
I was expecting to see some logs in the ingesters, but no.
Any idea of what could be missing? Or investigations I could do?
Here are our Tempo Helm custom values:
queryFrontend:
query:
# -- Required for grafana version <7.5 for compatibility with jaeger-ui. Doesn't work on ARM arch
enabled: false
ingester:
replicas: 2
search:
enabled: true
traces:
jaeger:
# -- Enable Tempo to ingest Jaeger GRPC traces
grpc: true
# -- Enable Tempo to ingest Jaeger Thrift Binary traces
thriftBinary: false
# -- Enable Tempo to ingest Jaeger Thrift Compact traces
thriftCompact: false
# -- Enable Tempo to ingest Jaeger Thrift HTTP traces
thriftHttp: false
# -- Enable Tempo to ingest Zipkin traces
zipkin: false
otlp:
# -- Enable Tempo to ingest Open Telementry HTTP traces
http: false
# -- Enable Tempo to ingest Open Telementry GRPC traces
grpc: true
# -- Enable Tempo to ingest Open Census traces
opencensus: false
# ServiceMonitor configuration
serviceMonitor:
# -- If enabled, ServiceMonitor resources for Prometheus Operator are created
enabled: true
# -- Namespace selector for ServiceMonitor resources
namespaceSelector: { matchNames: ["monitoring"]}
# -- Additional ServiceMonitor labels
labels: {app.kubernetes.io/monitoring: prometheus}
