Hi, there seems to be a problem using multi value option of Templating.
I’m using Grafana-4.4.1-1.x86_64.rpm
We have to select more than one selection to get data. If we select only one, there are no results but we know that there are since it works well without the multi value option selected.
Regards,
Following are both JSON.
JSON Templating with multi value:
"annotations": {
"list": []
"editable": true,
"gnetId": null,
"graphTooltip": 0,
"hideControls": false,
"id": 9,
"links": [],
"refresh": false,
"rows": [
"collapse": false,
"height": "300px",
"panels": [
"aliasColors": {},
"annotate": {
"enable": false
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"editable": true,
"fill": 2,
"grid": {
"max": null,
"min": null
"id": 12,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"links": [],
"loadingEditor": false,
"nullPointMode": "null",
"percentage": false,
"pointradius": 5,
"points": false,
"renderer": "flot",
"resolution": 100,
"scale": 1,
"seriesOverrides": [],
"spaceLength": 10,
"span": 6,
"stack": true,
"steppedLine": false,
"targets": [
"refId": "A",
"target": "aliasByNode(perSecond(servers.$Serveur.disk.dm-*.disk_ops.*), 1, 3)"
"thresholds": [],
"timeFrom": null,
"timeShift": null,
"title": "Disks Ops (Physical Local disks) / sec",
"tooltip": {
"msResolution": false,
"query_as_alias": true,
"shared": true,
"sort": 2,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "none",
"label": "",
"show": true
"format": "none",
"show": true
"zerofill": true
"repeat": null,
"repeatIteration": null,
"repeatRowId": null,
"showTitle": false,
"title": "Disks",
"titleSize": "h6"
"collapse": false,
"height": 250,
"panels": [],
"repeat": null,
"showTitle": false,
"title": "Dashboard Row",
"titleSize": "h6"
"schemaVersion": 14,
"style": "dark",
"tags": [],
"templating": {
"list": [
"allValue": null,
"current": {
"text": "lgra543p + lsup543p",
"value": [
"lgra543p",
"lsup543p"
"datasource": "Graphite-reseau",
"hide": 0,
"includeAll": false,
"label": null,
"multi": true,
"name": "Serveur",
"options": [],
"query": "servers.*",
"refresh": 2,
"regex": "",
"sort": 0,
"tagValuesQuery": "",
"tags": [],
"tagsQuery": "",
"type": "query",
"useTags": false
"allValue": null,
"current": {
"text": "dm-0",
"value": "dm-0"
"hide": 0,
"label": null,
"multi": true,
"name": "Disk",
"options": [
"selected": true,
"text": "dm-0",
"value": "dm-0"
"selected": false,
"text": "dm-1",
"value": "dm-1"
"selected": false,
"text": "dm-2",
"value": "dm-2"
"selected": false,
"text": "dm-3",
"value": "dm-3"
"selected": false,
"text": "dm-4",
"value": "dm-4"
"selected": false,
"text": "dm-5",
"value": "dm-5"
"selected": false,
"text": "dm-6",
"value": "dm-6"
"selected": false,
"text": "sda",
"value": "sda"
"selected": false,
"text": "sda1",
"value": "sda1"
"selected": false,
"text": "sda2",
"value": "sda2"
"selected": false,
"text": "sdb",
"value": "sdb"
"query": "servers.$Serveur.disk.*",
"refresh": 0,
"regex": "",
"sort": 0,
"tags": [],
"tagsQuery": "",
"type": "query",
"useTags": false
"time": {
"from": "now-5m",
"to": "now"
"timepicker": {
"collapse": false,
"enable": true,
"notice": false,
"now": true,
"refresh_intervals": [
"5s",
"10s",
"30s",
"1m",
"5m",
"15m",
"30m",
"1h",
"2h",
"1d"
"status": "Stable",
"time_options": [
"5m",
"15m",
"1h",
"6h",
"12h",
"24h",
"2d",
"7d",
"30d"
"type": "timepicker"
"timezone": "browser",
"title": "Analyse globale serveur Linux Rhl7",
"version": 2
JSON Templating without multi value
"annotations": {
"list": []
"editable": true,
"gnetId": null,
"graphTooltip": 0,
"id": 9,
"links": [],
"refresh": false,
"rows": [
"collapse": false,
"height": "300px",
"panels": [
"aliasColors": {},
"annotate": {
"enable": false
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"editable": true,
"fill": 2,
"grid": {
"max": null,
"min": null
"id": 12,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"links": [],
"pointradius": 5,
"points": false,
"renderer": "flot",
"resolution": 100,
"scale": 1,
"spaceLength": 10,
"span": 6,
"stack": true,
"targets": [
"refId": "A",
"thresholds": [],
"timeFrom": null,
"timeShift": null,
"tooltip": {
"shared": true,
"sort": 2,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "none",
"label": "",
"show": true
"format": "none",
"show": true
"zerofill": true
"repeat": null,
"showTitle": false,
"title": "Disks",
"titleSize": "h6"
"collapse": false,
"height": 250,
"panels": [],
"repeat": null,
"showTitle": false,
"titleSize": "h6"
"style": "dark",
"tags": [],
"templating": {
"list": [
"allValue": null,
"current": {
"text": "lgra543p",
"value": "lgra543p"
"hide": 0,
"label": null,
"multi": false,
"name": "Serveur",
"options": [],
"refresh": 2,
"regex": "",
"sort": 0,
"tags": [],
"tagsQuery": "",
"type": "query",
"useTags": false
"allValue": null,
"current": {
"text": "dm-0",
"value": "dm-0"
"hide": 0,
"label": null,
"multi": true,
"name": "Disk",
"options": [
"selected": true,
"text": "dm-0",
"value": "dm-0"
"selected": false,
"text": "dm-1",
"value": "dm-1"
"selected": false,
"text": "dm-2",
"value": "dm-2"
"selected": false,
"text": "dm-3",
"value": "dm-3"
"selected": false,
"text": "dm-4",
"value": "dm-4"
"selected": false,
"text": "dm-5",
"value": "dm-5"
"selected": false,
"text": "dm-6",
"value": "dm-6"
"selected": false,
"text": "sda",
"value": "sda"
"selected": false,
"text": "sda1",
"value": "sda1"
"selected": false,
"text": "sda2",
"value": "sda2"
"selected": false,
"text": "sdb",
"value": "sdb"
"refresh": 0,
"regex": "",
"sort": 0,
"tags": [],
"tagsQuery": "",
"type": "query",
"useTags": false
"time": {
"from": "now-5m",
"to": "now"
"timepicker": {
"collapse": false,
"enable": true,
"notice": false,
"now": true,
"5s",
"10s",
"30s",
"1m",
"5m",
"15m",
"30m",
"1h",
"2h",
"1d"
"status": "Stable",
"time_options": [
"5m",
"15m",
"1h",
"6h",
"12h",
"24h",
"2d",
"7d",
"30d"
"version": 2
