Templating init failed/ HTTP error 500
Hi community,
I’m a little bit confused, because there was no change from my side…
My grafana templating crashes and there is a HTTP error 500.
If I want to create a new configuration and select Graphite as the database, Icinga2 will no longer appear as a series.
Browser Error log:
The Graphite Database Test is ok.
Gaphite exeption.log:
Traceback (most recent call last):
File “/usr/lib/python2.7/dist-packages/django/core/handlers/exception.py”, line 41, in inner
response = get_response(request)
File “/usr/lib/python2.7/dist-packages/django/core/handlers/base.py”, line 249, in _legacy_get_response
response = self._get_response(request)
File “/usr/lib/python2.7/dist-packages/django/core/handlers/base.py”, line 187, in _get_response
response = self.process_exception_by_middleware(e, request)
File “/usr/lib/python2.7/dist-packages/django/core/handlers/base.py”, line 185, in _get_response
response = wrapped_callback(request, *callback_args, **callback_kwargs)
File “/usr/lib/python2.7/dist-packages/graphite/composer/views.py”, line 35, in composer
profile = getProfile(request)
File “/usr/lib/python2.7/dist-packages/graphite/user_util.py”, line 25, in getProfile
return default_profile()
File “/usr/lib/python2.7/dist-packages/graphite/user_util.py”, line 41, in default_profile
‘password’: ‘!’})
File “/usr/lib/python2.7/dist-packages/django/db/models/manager.py”, line 85, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File “/usr/lib/python2.7/dist-packages/django/db/models/query.py”, line 464, in get_or_create
return self.get(**lookup), False
File “/usr/lib/python2.7/dist-packages/django/db/models/query.py”, line 374, in get
num = len(clone)
File “/usr/lib/python2.7/dist-packages/django/db/models/query.py”, line 232, in len
self._fetch_all()
File “/usr/lib/python2.7/dist-packages/django/db/models/query.py”, line 1118, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File “/usr/lib/python2.7/dist-packages/django/db/models/query.py”, line 53, in iter
results = compiler.execute_sql(chunked_fetch=self.chunked_fetch)
File “/usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py”, line 899, in execute_sql
raise original_exception
OperationalError: no such table: auth_user
