Hey, I am using Telegraf with Telemetry, I want to see traffic level on interface based on their description, “/interfaces/interface/subinterfaces/subinterface/state/description”. Unfortunately the interface description was as field key, which I converted using the processors.converter. Since I needed to rewrite the data after this, I just dropped the whole measurement so the new tag can take place.
I do see the descriptions as tag fields and I do see the interface description as a tag key.
Unfortunately I am still getting blank results on any query when I try with querying by interface description.
Relevant telegraf.conf:
Convert values to another metric value type
[[processors.converter]]
Fields to convert
[processors.converter.fields]
tag = [“/interfaces/interface/subinterfaces/subinterface/state/description”]
System info:
Telegraf 1.14.5
Debian
Docker
Steps to reproduce:
select “/interfaces/interface/subinterfaces/subinterface/state/description” from “/interfaces/”
(empty result) this is expected since now its a tag
show tag keys
tagKey
show tag values with key = “/interfaces/interface/subinterfaces/subinterface/state/description”
(gives all descriptions)
SELECT “/interfaces/interface/subinterfaces/subinterface/state/counters/out-pkts” from /interfaces/ where “/interfaces/interface/subinterfaces/subinterface/state/description” = ‘some_description’
(empty result)
Expected behavior:
to give some a result for the interface with that description
Actual behavior:
(is not returning any result)
Am I using the correct fields here?
