Can anyone help me understand why I am getting a 422 error when using Add Team Member API call from a Python script? The server is running Grafana 5.3.4.
This is the function I am using:
def grafana_add_team_member(args):
team = grafana_get_team(args)
rest_url = "http://%s:%s/api/%s/%s/members" % (args.host, args.port, "teams", team['teams'][0]['id'])
print("URL: %s" % (rest_url))
print("DATA: %s" % (args.data))
try:
r = requests.post(url=rest_url, auth=(args.user, args.password), verify=False, data=args.data)
r_json = r.json()
if r.status_code == 200:
return(r_json)
else:
r.raise_for_status()
except ValueError:
raise Exception(r)
except Exception:
raise
And the output is this:
URL: http://grafana:3000/api/teams/9/members
DATA: {u'userId': 1}
error: the action 'add' for 'team_member' generated an error (422 Client Error: Unprocessable Entity for url: http://grafana:3000/api/teams/9/members).
I have double checked that there is a user with an ID of 1 and a group with an ID of 9, and that that group has no members.
I have another similar function for adding a team and that seems to work perfectly:
def grafana_add_team(args):
rest_url = "http://%s:%s/api/%s" % (args.host, args.port, "teams")
try:
r_json = r.json()
return(r_json)
else:
except ValueError:
raise Exception(r)
except Exception:
raise
I have also been able to get and delete teams using python and the API; it is only adding group members that is causing a problem. I mention this because I believe it indicates that the Python code is correct and that there is some problem with the data I am using, but as far as I can see that matches what is given in the API docs.
I am aware that I have not defined headers for the call, but I haven’t defined them or needed them to create or delete teams.
Thanks in advance for any assistance.
r0tty
