is it possible to add tag value to pannel description? For example:
state, host=dev1, location=“Prague” state=1.
In grafana variable i use “Value groups/tags (Experimental feature)”:
SHOW TAG VALUES FROM “state” WITH KEY = “host”
SHOW TAG VALUES FROM “state” WITH KEY = “location”
SHOW TAG VALUES FROM “state” WITH KEY = “host” WHERE location = ‘$tag’
Can I use something like “$tag” variable to autogenerate description of panels (for example Sigle panel)
Thanks for the response.
