Yes, the data is in Influxdb. I don’t know how to phrase a query directly - so far i’ve been using Open-NTI for Juniper switch stats and for that its fairly basic.
Even if I could set the limits of a gauge dynamically and have a single stat gauge for each site - my stats are really more like 10 of 30 devices online, 2 in maintenance.
Of what? I’m asking if its possible to do a table containing a row per series with the columns being multiple different measurements. I cant get anything close as is. I’ll post the JSON data im feeding into influxdb soon.
Thanks heaps - this really helps. So if my hostname is stored where your logins.count is how do I display the FROM as a tag(hostname)? Or should I add it as a field?
