Table - set alias to hostname
Does an alias method exist to replace the shown name of metrics to part of their existing name?
For example, see attached image. I’d like the metrics to just show the host name, removing the ‘% used memory’ item suffix, since it is redundant. (It’s pulling the info from Zabbix, in case it matters.)
Thank you for all guidance.
Metric-setAliasToHostname
I recently learned how to use Set Alias and Replace Alias. :slight_smile:
Really helpful - I can remove the metric type from the name, or even change the hostname to some alias.
Set Alias - fully replace the name
Replace Alias - change part of the name to blank or something else (i.e. remove the ‘% Used Memory’ or change host name from ‘TechySvrNameProd45’ to ‘DC1’
