Hey
I’m trying to send a custom HTTPS request via the synthetic monitoring solution send the request via postman works perfectly but sending it via the grafana monitoring solution its giving me error’s
Hey
Tell us what the errors are, otherwise we have no idea what problem you
have.
Do you have access to the log files on the server the request is being sent
to? If so, what appears there when Grafana attempts to fetch data?
Antony.
Hey Antony,
I think my question is I have a curl request with a few parameters and I’m sending a post to the endpoint with postman Its successful but using the http check on the synthetic is failing.
I would like to post more information but Its company specific related info on the curl request.
I think we are going to work on the API endpoint to simplify the response instead of a great body of json
Thanks again for your quick response
