I’m trying to install the synthetic monitoring agent to setup a private probe however when following the steps outlined in Private probes | Grafana Cloud documentation we’re failing to grab the key however the certificate is valid on the rpm.grafana.com endpoint
wget https://rpm.grafana.com/gpg.key
--2022-10-11 11:11:03-- https://rpm.grafana.com/gpg.key
Resolving rpm.grafana.com (rpm.grafana.com)... 151.101.130.217, 151.101.194.217, 151.101.2.217, ...
Connecting to rpm.grafana.com (rpm.grafana.com)|151.101.130.217|:443... connected.
ERROR: cannot verify rpm.grafana.com's certificate, issued by ‘/C=US/O=Let's Encrypt/CN=R3’:
Issued certificate has expired.
To connect to rpm.grafana.com insecurely, use `--no-check-certificate'.
