Syntax for using headers inside the client body of otelcol.exporter.otlphttp
I have defined a otelexporter in my pipeline but end with http 406 error, the documentation suggests that the file format is not known and hence the error. Now I have to pass ‘content-type:application/json’ in the header what should be the syntax? I tried below and it failed.
the documentation says the headers should be defined in the client block : otelcol.exporter.otlphttp | Grafana Agent documentation
otelcol.exporter.otlphttp "elastic" {
  client {
    endpoint = "https://elasticsearch:9200"
    auth = otelcol.auth.basic.elastic.handler
    headers{
      content-type=application/json
    tls{
      ca_file = "/path/to/certs.pem"
Have you figured out? I’ve tried the following, but none of them worked for grpc. I always got error: malformed header: missing HTTP content-type". Hope anybody can help.
headers = {“content-type” = “application/grpc+proto”}
headers = {“content-type:application/grpc+proto”}
headers = {“content-type = application/grpc+proto”}
