Unknown type: "headers_setter" for id: "headers_setter" (valid values: [health_check pprof zpages memory_ballast])
unknown type: “headers_setter” for id: “headers_setter” (valid values: [health_check pprof zpages memory_ballast])
We have installed otelcol version 0.75.0 and trying to send traces to otel trace gateway collector running on port 4317 .
When i try to run the otel collector running on linux machine , it throws error unknown type: “headers_setter”
below is our configuration file -
extensions:
  headers_setter:
    headers:
      - action: upsert
        key: X-Scope-OrgID
        value: devenv
receivers:
  otlp:
    protocols:
      grpc:
      http:
exporters:
  otlphttp:
    endpoint: https://TRACEGW.DOMAIN:4317
    tls:
      insecure_skip_verify: true
    auth:
      authenticator: headers_setter
service:
  extensions: [headers_setter]
  pipelines:
    traces:
      receivers: [otlp]
      processors: []
      exporters: [otlphttp]
Our aim is to send headers from otel-collector to otel gateway configured to receive headers and then to tempo as traces backend-
Any suggestions would be very helpfull.
That’s minimal distribution with minimum number of components. Use contrib distribution. Or build own distribution with components, which you need for your case.
indeed ,missed that point , thanks for the reply .
