Do you know if this is possible to sync the view of a selected metric on all graph?
Example:
- We have a graph1 with metric1 / metric2 / metric3
- We have a graph2 with metric4 / metric2 / metric5
The idea is to extend the “hover tooltip” to select metric. So in this example, if I select metric1, only metric 1 from graph1 will be showed (this is currently the case). If I select metric 2, the goal is to select metric2 on all graph of the dashboard.
I don’t know if this clear, doesn’t hesitate if you need more informations.
Iit seems to me that it worked in the past or I dreamed…
Thank you very much!
Best regards,
