Sum total number of items returned by a LogQL qery
Hi, with following query i get total number of logs by label “SipSessionId”.
That’s ok, but i would like to have in my stat graph just total number of “unique” SipSessionId labels.
Is this possible?
QUERY:
sum by (SipSessionId)(count_over_time({origin=“MYORIGIN”, SipSessionId=~“.+”} [$__range]))
Could you show what you expect to have?
I would like to have a simple graph, like shown, that rapresents total number of “unique” sipsessionid labels.
Can you try the query:
count(count_over_time({origin="MYORIGIN", SipSessionId=~".+"}[$__range]) by (SipSessionId))
Your code give me an error.
I have to adjust like this:
count(count_over_time({origin=“MYORIGIN”, SipSessionId=~“.+”} [$__range])) by (SipSessionId)
but I already tested and I realized that i get same identical result of using “sum by”
Okay, what else did you already try?
What’s the error?
Played around “count”… count by, sum, etc but cannot get what i need.
If you meant error related to your preview code, this is error:
“request”: {
“url”: “api/ds/query?ds_type=loki&requestId=Q936_1”,
“method”: “POST”,
“data”: {
“queries”: [
“datasource”: {
“type”: “loki”,
“uid”: “advz300kmjgg0e”
“editorMode”: “code”,
“expr”: “count(count_over_time({origin="MYORIGIN", SipSessionId=~".+"}[$__range]) by (SipSessionId))”,
“queryType”: “range”,
“refId”: “A”,
“legendFormat”: “”,
“maxLines”: 1000,
“datasourceId”: 58,
“intervalMs”: 60000,
“maxDataPoints”: 1179
“from”: “1725191357852”,
“to”: “1725277757852”
“hideFromInspector”: false
“response”: {
“results”: {
“A”: {
“error”: “invalid request”,
“errorSource”: “downstream”,
“status”: 500,
“refId”: “A”
Seems similar to this issue, can you take a look at it?
Tried but not luck.
See error. Always it returns “invalid request” and cannot understand why
QUERY:
count by (SipSessionId)(sum by (SipSessionId)(count_over_time({origin=“MYORIGIN”, SipSessionId=~“.+”} [$__range])))
“request”: {
“url”: “api/ds/query?ds_type=loki&requestId=Q956_1”,
“method”: “POST”,
“data”: {
“queries”: [
“datasource”: {
“type”: “loki”,
“expr”: “count by (SipSessionId)(sum by (SipSessionId)(count_over_time({origin="MYORIGIN", SipSessionId=~".+"} [$__range])))”,
“queryType”: “instant”,
“refId”: “A”,
“legendFormat”: “”,
“maxLines”: 1000,
“datasourceId”: 58,
“intervalMs”: 86400000,
“maxDataPoints”: 1
“from”: “1725192327381”,
“to”: “1725278727381”
“response”: {
“results”: {
“A”: {
“status”: 500,
“refId”: “A”
Ok, I’m not so good with Loki, sorry…
Looks like Loki’s having issue to count a sum (which makes sense…).
Why the result of your query:
sum by(SipSessionId)(count_over_time({origin="MYORIGIN", SipSessionId=~".+"} [$__range]))
doesn’t suit you? Looks like the total of unique labels to me…
This is what i need at the end.
Sound strange grafana cannot do this simple achivment.
Okk! Make sense.
Can you show me what you get using:
Also, I quite sure that keeping your actually query and adding a new transformation you can achieve the sum of each statement and get 6…
Also can you take a look at this?
Using following query give me same identical result.
Trying query of this link give me error on query. Alway same error of “ivalid request” :frowning:
count(count(count_over_time({origin=“MYORIGIN”, SipSessionId=~“.+”} [$__range])) by (SipSessionId))
Well… I’m sorry but I’ll not be able to help you furthermore…
Finally!!! Found solution with transformation!!
QUERY
