v9.5.1 (bc353e4b2d) (kube-prometheus-stack-45.27.2)
macOS Client → Safari -
I would like to have the same sum for the data no matter the interval. -
sum_over_time, rate_counter -
What happened?
The overall sum is different with a different interval. -
I expect to show the same data. -
sum_over_time({jobtype="pushlogs", x_host_header=~"$Host"} | pattern `<_> <_> <_> <sc_bytes> <_>` | unwrap sc_bytes [$interval]) -
No -
No
Please mind the screenshots and the “total” value. Can anyone explain why this is happening?
