Suggestions to display the date or time since a particular date
I want to monitor and highlight when data in tables has not been updated for a while. The tables all have CreateDate fields so I use the last CreateDate to determine if the table has not been written to for X hours by using a max(CreateDate) in the SQL
What would be the best way to represent this on a Grafana Panel? It would be great to see it going amber when it’s close to too old and then red when it is out of date.
I’m looking for the same thing since two days now
How about use a Stat panel to display the last Create date? Not sure if you will be able to set up thresholds (color of Stat panel to change) based on X hours or such, but you can try.
More info to get you started here: How to show time of min (or max) value? - #4 by viapass
I found a solution for me:
I displayed the date in a table graph and then hid the panel like this
Screenshot from 2021-03-10 09-57-51
Screenshot from 2021-03-10 09-58-07
then i added text panel and with some javascript code i got the date and displayed the difference
Screenshot from 2021-03-10 10-01-36
Can you share the javascript code that you used in the Text panel to get the date & display the difference?
setTimeout(() => {
var x = document.getElementsByClassName(β€œcss-1hlp2kn”);
var date = 0
for (i = 0; i < x.length; i++) {
if (x[i].innerHTML.startsWith(β€œ20”)) {
if (Date.parse(x[i].innerHTML) > date) {
date = Date.parse(x[i].innerHTML)
var now = new Date();
var diff = now - date;
var msec = diff;
var hh = Math.floor(msec / 1000 / 60 / 60);
msec -= hh * 1000 * 60 * 60;
var mm = Math.floor(msec / 1000 / 60);
msec -= mm * 1000 * 60;
var ss = Math.floor(msec / 1000);
msec -= ss * 1000;
if (hh > 0) {
hh = (β€œ0” + hh).slice(-2)
res = hh + β€œ:” + mm + β€œ:” + ss
} else {
mm = (β€œ0” + mm).slice(-2)
ss = (β€œ0” + ss).slice(-2)
res = mm + β€œ:” + ss
$(’#lastUpdate’).text(res);
}, 4000);
