Dylan
1
brew update
brew install grafana
and
brew services start grafana
show
==> Successfully started grafana (label: homebrew.mxcl.grafana)
but when I go to http://grafana.staged-by-discourse.com/, it doesn’t respond.
I don’t know which step I did wrong.
Hi
on what OS you install GRAFANA ?
when you go to http://grafana.staged-by-discourse.com you use same machine where you installed GRAFANA or other ?
Dylan
3
hi
I use macOS Big Sur(11.2.3)
and path is /usr/local/Cellar/grafana/grafana
do you use a virtual machine ?
Dylan
5
hi,I use my macbook really…
It’s mandatory to install it on mac Os or you can also install it on Linux ?
Dylan
7
maybe when I rename the grafana folder, something wrong.
i reinstall grafana, and it works working.
Dylan
8
thanks blau9175
have a nice day
