Succesfully have a Synthetic Test
Hey,
I’m investigating Grafana Synthetics and created some browser checks with the Chrome Recording and k6 DevTools. The issue I’m facing is that the script succeeded four steps of the check, which is in total five, but then it fails. I tried this on the Grafana website. I can’t add attachments… Who can help me with this issue?
Thanks in advance.
Frank
Script:
// Code generated by ⛰ k6 DevTools Recorder
import { browser } from 'k6/browser';
import { check } from 'k6';
import { Runner } from "https://jslib.k6.io/k6-replay/1.0.0/index.js"
export const options = {
  scenarios: {
    browser: {
      executor: "shared-iterations",
      options: {
        browser: {
          type: "chromium",
  thresholds: Runner.thresholds,
export default async function() {
  const runner = new Runner({
    title: "Grafana test",
    steps: []
  await runner.runBeforeAllSteps()
  await runner.runStep({
    type: "setViewport",
    width: 1602,
    height: 964,
    deviceScaleFactor: 1,
    isMobile: false,
    hasTouch: false,
    isLandscape: false
    type: "navigate",
    assertedEvents: [{
      type: "navigation",
      url: "https://grafana.com/",
      title: "Grafana: The open observability platform | Grafana Labs"
    type: "click",
    target: "main",
    selectors: [
      ["aria/Products"],
      ["ul.mega-menu__primary a:nth-of-type(1)"],
      ["xpath//html/body/header/div[1]/div[1]/ul[1]/li/a[1]"],
      ["pierce/ul.mega-menu__primary a:nth-of-type(1)"]
    offsetX: 42.109375,
    offsetY: 7
    type: "click",
    assertedEvents: [{
      type: "navigation",
      url: "https://grafana.com/products/cloud/synthetic-monitoring/",
      title: ""
    target: "main",
    selectors: [
      ["div.active div:nth-of-type(4) a:nth-of-type(2) p.copy"],
      ["xpath//html/body/header/div[1]/div[2]/div/div[1]/div/div[1]/div[4]/div/div[1]/a[2]/div/div/p[1]"],
      ["pierce/div.active div:nth-of-type(4) a:nth-of-type(2) p.copy"]
    offsetX: 34.015625,
    offsetY: 29.09375
    type: "click",
    assertedEvents: [{
      type: "navigation",
      url: "https://grafana.com/docs/grafana-cloud/testing/synthetic-monitoring/create-checks/public-probes/?pg=synthetic-monitoring&plcmt=features",
      title: ""
    target: "main",
    selectors: [
      ["aria/more than 20 Grafana managed probe locations"],
      ["div:nth-of-type(4) div.order-2 a:nth-of-type(1)"],
      ["xpath//html/body/div[1]/div/div[4]/div/div/div[1]/div/div/div/ul/li[3]/a[1]"],
      ["pierce/div:nth-of-type(4) div.order-2 a:nth-of-type(1)"],
      ["text/more than 20 Grafana"]
    offsetX: 118,
    offsetY: 10.75
    type: "click",
    assertedEvents: [{
      type: "navigation",
      url: "https://grafana.com/docs/grafana-cloud/testing/synthetic-monitoring/set-up/set-up-private-probes/",
      title: ""
    target: "main",
    selectors: [
      ["aria/Private probes"],
      ["p:nth-of-type(3) > a"],
      ["xpath///*[@id=\"doc-article-text\"]/p[3]/a"],
      ["pierce/p:nth-of-type(3) > a"]
    offsetX: 88.65625,
    offsetY: 9.8125
  await runner.runAfterAllSteps()
Hi Frank,
I’ve run the script and can see the problem lies in the query parameters being added in the fourth step. If you add ?pg=synthetic-monitoring&plcmt=features to the fifth URL the test will pass.
Hope that helps!
hi
you can just delete the line
