If I have a plugin I’d like to get listed, what’s the process for that?
Hi @farski,
Thanks for your interest in Grafana plugin development!
You can create a pull request on this GitHub project: https://github.com/grafana/grafana-plugin-repository. Plugin development guidelines are also listed there.
Thanks @adeverteuil. What’s the normal turn around on getting things reviewed?
We’re trying to review plugins on a weekly basis. It takes a least a few days to get one published, though it’s typical changes are needed and that slows down the process.
Panels are usually quick to review. Datasources are more involved. Anything a plugin author can do to make it easy to test/validate speeds up the process
You can see the schedule here: https://github.com/grafana/grafana-plugin-repository/projects/1
