fvahid
September 22, 2024, 1:00pm
1
Hi, I just created PR to solve redirection problem in organization change but did not receive any feedback from community about relate issue Bug into the link to change the organizzation · Issue #89321 · grafana/grafana · GitHub
It doesn’t look hood to me. Did you test with Grafana behind reverse proxy?
I guess it’s config issue, not a bug. Original poster didn’t sent used config, so it is hard to prove it.
fvahid
September 23, 2024, 7:38am
3
Thanks for your attention
I test with revers proxy also, is not config issue because when we set domain in config grafana redirect to domain set that in config file but problem when occur when we use grafana behind the reverse proxy with differ domain or sometimes with 2 and more that 2 domain in proxy
fvahid
September 23, 2024, 11:10am
4
grafana:main ← fvahid:main
opened 08:54AM - 14 Sep 24 UTC
**What is this feature?**
Stop Redirecting grafana url base on conf file when w… e change organization
[Organization change in main page.]
**Why do we need this feature?**
[Redirect URL when don't need to this redirection.]
**Who is this feature for?**
[all grafana users.]
**Which issue(s) does this PR fix?**:
Fixes #https://github.com/grafana/grafana/issues/89321
**Special notes for your reviewer:**
Please check that:
- [ ] It works as expected from a user's perspective.
- [ ] If this is a pre-GA feature, it is behind a feature toggle.
- [ ] The docs are updated, and if this is a [notable improvement](https://grafana.com/docs/writers-toolkit/contribute/release-notes/#how-to-determine-if-content-belongs-in-whats-new), it's added to our [What's New](https://grafana.com/docs/writers-toolkit/contribute/release-notes/) doc.
pull request linke to solve this problem
