Status timeline not working with PostgresSQL and only one Query
Hello everyone!
I’m creating a dashboard in Grafana with data extracted from Google Servers and stored in a PostgresSQL Database.
In one of the visualization I would like to create a Status Timeline:
I have created a query in PostgresSQL which returns me the following table:
As my understanding goes, that is the data that is need to create a Status Timeline. (Time, count of a variable and name of the variable count).
But when I copy that query inside Grafana, the chart is not the same as I have imagined:
I don’t know what else to do or how to fix it.
Does anyone has faced this issue before or know how to solve it, in order to get a Status Timeline like the one showed above?
Thank you very much!
@jorgelopezmuah
Check this out here and see if it provides you some guidance
https://play.grafana.org/d/qD-rVv6Mz/6-state-timeline-and-status-history?orgId=1
you need to configure your data as time series not just table
Hi there yosiaz:
Thanks for your fast reply :). I’ll try the time series.
I see in your picture that you use two different queries (A and B ) to show the values (asia-dev and asia-hotfix).
Can it be done in just one single query ( In A ). That’s what I’m looking for.
I was not able to do it with one query.
Okay no worries! Thank you very much for your effort and time.
I hope someone has already faced and conquer this issue :slight_smile:
