State timeline value into vertical
I am using a state timeline graph to visualise my values inside the graph, but unfortunately it’s overriding each other, is there any way where I can switch the value into vertical inside the graph?
Also I am using a discrete graph in which I am unable to map the colors for the values.
question:
is it possible to change the text alignment to vertical?
Did you ever manage to achieve this, please?
Hi, did anybody find a solution yet? I am also interested in this.
