Is there a way to ignore events shorter than X minutes in the State Timeline?
Example: a device is online for 2 hours, then offline for 3 seconds, then back online for another 5 hours. Ignore states that lasts for less than one minute so the chart would display that the device was online for 7 hours.
@adrianatcrimsonauzre hey there, welcome to the forum
I don’t believe that you can set a time threshold like that using the state-timeline’s panel editor. Maybe this is something that you could solve at the query level instead?
Also, it’s a cool idea. Might be worth starting a discussion about an enhancement request over on the repo
